383 stroker camshaft suggestions
Old Mar 19, 2011 | 04:10 PM
berlinettajake's Avatar
Car: 84 camaro berlinetta
Engine: 383 stroker Bored .40 over
Transmission: th-400 hughes 2500 Stall
Axle/Gears: moser axles 3.73 gears
Got A 383 Looking For Some Suggestions For A Cam Heres What I Got In The Motor. Engine Wraps out Around 5500-6000 RPM I Realize You Want To Be Around 100-300 Of The Stall Range So Just Looking For A Cam That You Guys Have Had Good Results With. Thanks For The Help!
70's Hardened Block
4 Bolt Main
Eagle Crank Externally Balanced
Clevite Rod And Crank Bearings
Eagle Rods
Speed Pro Flat Top Pistons With Moly Rings .40 Over
Hydraulic lifters
Hardened Pushrods
Double Roller Timing Chain
Adding Brodix 180 Heads
Victor jr. intake
Holley Double Pumper 750
turbo 400 hughes 2500 stall
junior419
Apr 7, 2025 11:35 AM
83RDRACR
Mar 26, 2016 08:13 PM
buckshot63
Sep 10, 2015 09:15 AM
!CamaroDave
Members Camaros
Sep 5, 2015 10:39 AM
