DUI dist.
Old Mar 24, 2011 | 07:16 PM
hartman's Avatar
Car: 1992 firebird
Engine: SBC 350
Transmission: TH350
DUI dist.
do the ones off summit come tuned also? Do you just submit your info later? I ask because they are on sale on summit.
Old Mar 24, 2011 | 11:45 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: DUI dist.
No distributor comes "tuned" - there's nothing to "tune" with it. IT itself is used to tune your car. Got a link to which dist you are referring to?
Old Mar 25, 2011 | 06:53 AM
hartman's Avatar
Car: 1992 firebird
Engine: SBC 350
Transmission: TH350
Re: DUI dist.
by tuned i mean weights and vacuum advanced set already for total timing.
Old Mar 25, 2011 | 09:44 AM
Car: 1992 RS
Engine: Carbed 350
Re: DUI dist.
That is again going to depend on your motor. Most distributors come with extra weights and springs so that you can swap to get the right setup to get the total timing you want, but you'll have to do the swapping of them and test until you get the right combination. If it doesn't come with them, they are available seperately.
Again, have a link to what your looking at?
Old Mar 25, 2011 | 10:08 AM
hartman's Avatar
Car: 1992 firebird
Engine: SBC 350
Transmission: TH350
Re: DUI dist.
no you give them the specs of your car,cam, and uses and they tune it to your car so you arent messing with weights and springs and the vacuum advance but nevermind i just called summit and they dont if u want it tuned for your car you gotta go through DUI.
http://www.performancedistributors.com/
Old Mar 25, 2011 | 11:13 AM
Car: 1992 RS
Engine: Carbed 350
Re: DUI dist.
OK I see. I just as soon do it myself for the extra $100+ they want over any on the shelf distributor.
Old Mar 25, 2011 | 11:19 AM
hartman's Avatar
Car: 1992 firebird
Engine: SBC 350
Transmission: TH350
Re: DUI dist.
well its better than your off the shelf dist also.
pjsparts
Oct 29, 2025 06:39 PM
apo_bailon15
Mar 28, 2016 05:20 AM
db057
Aug 22, 2015 08:17 PM
Rallyssport
Aftermarket Product Review
Jun 8, 2001 12:56 AM
Wayquick4u
Mar 13, 2001 06:50 AM
