Are you using the 3 braces on serpentine set up?
Old Apr 1, 2011 | 09:05 AM
bconwayls1's Avatar
Hi guys, very informational site you have here. The Team Chevelle site recommends ya quite often, so here I am. I tossed a lil 92 305 from a caprice in my chevelle, but with headers and tall valve covers, the braces wont fit. Are they really necessary? Thank you!
Old Apr 1, 2011 | 09:32 AM
Twin_Turbo's Avatar
Re: Are you using the 3 braces on serpentine set up?
Yes, I have 2 broken brackets because the braces were loose or missing. With headers they are easily made to work, all you need is a longer stud, a sleeve to space the header flange to the thickness of a cast manifold and a nut. There really is nothing to it.
Old Apr 1, 2011 | 09:57 AM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Spacers are available in the hardware section of Home Depot, they are metal, about 1.5 inches long, and about a 3/8 hole in them. Then, just use longer studs/bolts.
Old Apr 1, 2011 | 10:26 AM
bconwayls1's Avatar
Thanks guys. I had thought about weldig a stud to he header flange and re working the braces to fit. I just didn't want to go through the effort if you guys don't use them.
Old Apr 1, 2011 | 11:22 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Second link in the following thread provides part numbers and instructions:
https://www.thirdgen.org/forums/afte...rsion-kit.html
In the thread there are various pics of braces and spacers.
JamesC
1992 Trans Am
May 10, 2023 07:19 PM
evilstuie
Jan 9, 2020 08:29 PM
evilstuie
Apr 14, 2016 08:52 PM
mustangdmurder
Aug 21, 2015 07:17 PM
jahblah
Aug 12, 2015 05:54 PM
