need help
Old Apr 4, 2011 | 11:41 PM
jollythought's Avatar
Car: 1983 Trans Am
Engine: Lu5
Transmission: TH700R4
need help
I cant seem to find the right walbro fuel pump for my 83 trans am. I'm not sure if i need a specific type, because the descriptions are 1985-2002. any help would be appreciated.
Old Apr 5, 2011 | 12:40 PM
HF_monster's Avatar
Car: 86' z28 (died 5/1/11) 76 k10 pickup
Transmission: th350
Axle/Gears: 3.73 open
Re: need help
they didnt start using electric fuel pumps till 85 with fuel injection you should have a mechanical fuel pump on the engine its on the front bottom left side looking from the front of the car.
Old Apr 5, 2011 | 12:47 PM
Car: 1983 Trans Am
Engine: Lu5
Re: need help
ok thanks for the help
Old Apr 5, 2011 | 12:57 PM
Car: 1983 Trans Am
Engine: Lu5
Re: need help
I'm a little confused now. I hear that it uses a mechanical pump but I've also read that the crossfire fuel system used an in tank fuel pump and I'm not sure. I havent been able to actually see my car for a couple of weeks so I haven't checked for myself.
Old Apr 5, 2011 | 01:49 PM
HF_monster's Avatar
Transmission: th350
Re: need help
worst case pull the pump and take it with you to the parts store and have them cross refernce it. now that you mention it some had a elcetric in tank and a mechanical pump if I recall corectly.
Old Apr 6, 2011 | 11:49 AM
Car: 1983 Trans Am
Engine: Lu5
Re: need help
I guess I have no choice but to go ahead and remove the gas tank, Thanks for the advice
Old Apr 6, 2011 | 12:00 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: need help
Crossfire uses an in-tank electric pump, no mechanical.
