Vacuum hoses
Old Apr 8, 2011 | 12:03 AM
Firebird Mess85's Avatar
Car: 85 Firebird & Grand Prix GXP
Engine: LG4 305 (originally 2.8L V6)
Axle/Gears: 10 bolt 3:43 Open Diff.
Vacuum hoses
I've got a vacuum line mess and I'm trying to replace them all rather than try to use t's and connectors to fix the broken ones. Is this a bad idea?
From anyone elses experience, can I reuse the elbows and connectors? Any idea where to get a kit if it's made with everything already in it? Also, what sizes are the hoses, I know 3/8" and a couple others?
I've got an E4ME CCQ-jet right now and was thinking of going to a carb with mechanical secondaries and put in an HEI distributor with vacuum advance down the line if this makes a difference. I know a lot of the vacuum lines are carb related right now. Am I better off just swapping carbs and distributors to eleminate having to sort through this?
Old Apr 8, 2011 | 12:42 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Vacuum hoses
You can reuse anything that isn't broken. The big stuff is 3/8", the small stuff is around 5/32".
Fix it all and you'll have better mileage, better driveability, lower emissions, and the same power as if you replace it.
Pac J
May 17, 2020 10:44 AM
sheachopper
Jul 31, 2019 11:27 AM
FormulasOnly
Jul 23, 2018 08:47 AM
HoosierinWA
Oct 7, 2015 10:15 AM
dusterbd
Sep 29, 2015 08:40 AM
