Yet another cam selection thread
Old Apr 13, 2011 | 11:20 AM
windowrattler's Avatar
Car: 92 RS, 89 Formula, 84 Iroc
Engine: Carb 350, TPI 305, TBD
Transmission: T-5, 700r4, TBD
Axle/Gears: 3.42 Posi, 3.08 Posi, Moser 3.73
Engine is a 1 pc main, 350 .030 over. Has '92 350 64cc tpi heads with a mild spring upgrade (think cheap comp cams springs). Engine sits at 9.7:1 compression. Intake is a edelbrock performer and 600 cfm carb. T-5 with 3.42 gears in the back. The two cams that I came up with are these:
COMP Cams CL12-238-2 http://www.summitracing.com/parts/CCA-CL12-238-2/COMP Cams CL12-242-2 http://www.summitracing.com/parts/CCA-CL12-242-2/
I was leaning toward the slightly smaller one as I've read that a lot of people tend to over cam. What do you guys think?
Street Lethal
Apr 30, 2019 12:14 PM
xbmx89
South Central Region
Oct 31, 2015 10:59 AM
camaro71633
Sep 1, 2015 10:24 AM
LT1Formula
Aug 20, 2015 09:36 PM
mizz0313
Aug 12, 2015 06:45 AM
