bad idle air control valve?
Old Apr 23, 2011 | 02:05 PM
peicheff's Avatar
Car: camaro iroc-z
Engine: 305 tpi
Transmission: 5 speed
i had my idle air control valve off due to constant stalling, i put it back on, started it up and it died right away, then took it off again and started it up and rpm instantly rose to 2500, does this mean the idle air control valve is bad?
Old Apr 24, 2011 | 01:02 AM
elpulpo's Avatar
Re: bad idle air control valve?
well looks like it is the iac valve,try to get the 1 1/8 ,some times the pin wont move at all
Old Apr 24, 2011 | 12:38 PM
Stevolwevol's Avatar
Car: 86 IROC Z, 92 RS
Engine: 305 4bbl, 305 TBI
You would need to run a diognostic test to figure out what the culprit is for sure. I replaced my IAC due to stalling, and Idling too high. I just took an educated guess, but it did the trick.
eightsixseven
Dec 16, 2024 01:50 PM
specialized
Jun 18, 2022 09:26 AM
backtothe80s
Sep 5, 2015 12:39 AM
db057
Aug 22, 2015 08:17 PM
