Fuel Pump Not Priming, Need Help Please
Old Apr 29, 2011 | 07:27 PM
BOSS HOGG LOU's Avatar
Car: 87 IROC Z28
Engine: 5.7 TPI
Axle/Gears: BW 9 Bolt
When I turn the key to the ON position I do not hear the fuel pump prime. I applied 12v to the G terminal and heard the fuel pump run, so that works. I checked all the fuses under the dash, everything is okay there. I have replaced the fuel pump relay, still no fire. The engine runs when starting fluid is spray into the throttle body. But right now, it just cranks and doesn't fire up. So I need help with what to look for next. I read another thread that told to check the fuse by the battery and the radiator, but I could not find a fuse, only a relay. The car has been pretty healthy until this, nothing is rigged in the car so it should run fine. Thanks in advance for any help.
Old Apr 30, 2011 | 02:44 PM
Car: 87 IROC Z28
Engine: 5.7 TPI
Re: Fuel Pump Not Priming, Need Help Please
Any suggestions on what I should check or replace next?
Old Apr 30, 2011 | 05:49 PM
86recaroTA's Avatar
Car: 1986 Trans AM
The fuse under the hood is inside a waterproof cap. Follow your pos battery wire til two smaller wire split off of it, one will goto the fuse. The split on car is abot 8 inches from the terminal.
Old Apr 30, 2011 | 06:20 PM
89RESTO's Avatar
2011 Norwood Gathering
ThirdGen Camaro Rep
Car: 1989 IROC
Engine: 5.7
Axle/Gears: 9 bolt 2:77
Depending on what year you have, the fuse may also be mounted to the pass. Side fender right next to the battery in a weather tight connector.Be sure to look behind the relay that you found because the fuse is kinda hidden.
Old May 2, 2011 | 04:29 AM
Car: 87 IROC Z28
Engine: 5.7 TPI
It was a 2 wire plug that was mounted to the passenger side fender. Sure enough, the fuse was blown. Changed out the fuse and it fired right up. Thanks for your help guys. Now on to upgrade the ignition.
Old May 2, 2011 | 07:12 AM
89RESTO's Avatar
ThirdGen Camaro Rep
Car: 1989 IROC
Engine: 5.7
Glad to hear you found the problem. Good luck with your ignition upgrade.
Glowsock
Jul 24, 2025 03:15 PM
Frozer!!!
Jan 19, 2024 04:55 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
92camaroJoe
Aug 13, 2015 06:07 AM
