hissing, HELP!!!!!
Old Apr 29, 2011 | 10:19 PM
sbc4life's Avatar
hissing, HELP!!!!!
when i was accelorating in my camaro, it would hiss, but when i stop there would be no hissing.... help??
Old Apr 29, 2011 | 11:11 PM
drknow90rs_ss@y's Avatar
Car: 86 IROC-Z, '71 RS
Engine: 305 TPI/ 350
Transmission: 700R4/TH350
Re: hissing, HELP!!!!!
Maybe you have an angry snake stuck under your car? Ok, J/K!
You probably have an exhaust leak. Have a friend who is wearing a glove(s) Plug your exhaust while you listen. Should make it more obvious and easier to hear.
Old Apr 29, 2011 | 11:26 PM
grassyflats's Avatar
heater core
Old Apr 29, 2011 | 11:30 PM
sbc4life's Avatar
it was coming from the driver side an almost sounded like a tire defalting
Old Apr 30, 2011 | 01:24 AM
fireburdluvr85's Avatar
Car: 91 formula ws6
Engine: 355 tpi OBDII
Transmission: 4l60E
Axle/Gears: 2.73 with 4th gen brakes
vacuum leak. sure its not from under the dash? i had my heater control diaphragm go bad and it hissed forever. was annoying cause it got louder when you got on it.
Old Apr 30, 2011 | 06:53 PM
ninetyone's Avatar
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
Could be a vacuum leak . Get an assistant to sit in your car and open your hood to listen for the sound right as your assistant turns the motor off. You should be able to hear a sucking, or hissing sound as the motor dies.
BurlyChev
Aug 16, 2015 09:08 PM
91L98Z28
May 9, 2002 01:01 PM
91L98Z28
Apr 9, 2002 12:35 PM
mult68
Mar 25, 2002 10:52 AM
zupmanZ28
Apr 9, 2001 06:56 AM
