Help. Rag joint removal
Old May 1, 2011 | 01:03 PM
native1031's Avatar
Im repairing just the power steering gear box and the rag joint.
How do I get the rag joint out after i take the bolt out?
Old May 1, 2011 | 01:07 PM
Re: Help. Rag joint removal
Pull the whole shaft, from the bottom of the column to the gear; drill the rivets.
Old May 1, 2011 | 01:21 PM
native1031's Avatar
How do I or what tool do i use to get to the bolt under the break booster. Its in a tight space
Old May 1, 2011 | 01:24 PM
tight space
It's kind of right out in the open. All that's in the way, is that block heater (or whatever it is) cord.
IIRC it's about a 16mm nut. A ratchet, extension, and socket work fine.
Old May 1, 2011 | 01:51 PM
native1031's Avatar
Haha it looks much easier in the pic. The bolt is on the drivers side of the shaft. The other end is round
The circled part is the round end i was talking about
Old May 1, 2011 | 02:22 PM
native1031's Avatar
I have my car up on ramps instead of jack stands. What if I were to put it on stands and turn the wheel so the bolt is facing upward?
am I going to encounter problems when reinstalling. What if i took the bolt off and then turn the wheel straight again and then take the shaft out?
Old May 1, 2011 | 04:10 PM
I knew you could figure it out!!
Although, it'll be the nut you'll want facing up. The bolt is just a round head, no drive, with a square shank fitting through a square hole in the shafts.
No need to worry about turning anything. Just slide it apart, pull out the shaft, leave the column and gear alone, replace the joint, and put it back in. It only goes one way on the gearbox.
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
TheExaminer
Sep 6, 2015 11:40 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
RyanJB
Sep 2, 2015 01:27 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
