Fuel pump localisation.
Old May 4, 2011 | 06:09 AM
1o80b's Avatar
Will it work if I put the fuel pomp here?
Some poeple tell that it will not work because I will not have enought PSI
Old May 4, 2011 | 10:00 AM
TNT_Z28's Avatar
Car: 1987 Camaro Z28
Engine: 355ci, XE262 , 650dp
Transmission: T-5, RAM clutch
Axle/Gears: 3.23 limited slip
Re: Fuel pump localisation.
I've seen those mounted on the block. I don't see how that could be a bad spot, just gives u more room.
Old May 4, 2011 | 10:13 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Gerotor pumps don't like sucking too much, you might have trouble getting it to prime.
Old May 4, 2011 | 11:23 PM
jmj1981's Avatar
Car: 1991 pontiac firebird
Engine: 3.1
Transmission: 700r
a pump like that will push the fuel better then pull it get it as close to the tank as you can
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
