G118 Ground Wire
Old May 9, 2011 | 11:45 AM
djmarch's Avatar
Car: 1989 GTA - Gunmetal grey
Engine: 5.7 ltr.
Axle/Gears: 3:27 9 Bolt Borg Warner
G118 Ground Wire
I've been told there is a G118 blk/white striped ground wire that grounds to the passengers side head between it, and the firewall. It is a ground for the ECM. Sources say if you have an ECM acting up, this can be a culprit. The only thing is I can't locate it on mine. What harness does this ground wire come out of ? The one that snakes over from next to the coil to the heater/ac box ?
Old May 9, 2011 | 12:25 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: G118 Ground Wire
Only thing I've ever seen was a regular groundstrap (woven bare copper) from pass side head to firewall.
BUT - I have seen 2-3 grounds connected to the top pass side tranny/engine bolt. Maybe that's what you are hunting for? I never paid attention to colors - those wires are at best a PITA to reconnect let alone actually being able to see the colors - but they have to be grounds for something.
I'm surprised that a ground for the ECM wouldn't just attach to the body somewhere inside the car, since the body should be grounded at the battery as well as at the pass head/firewall groundstrap. But no one ever said GM engineers were rocket scientists.
Old May 9, 2011 | 02:18 PM
HawkZ28's Avatar
Car: 86 Z28
Engine: Built 312
Axle/Gears: 10 bolt 3.42
True even though they claim to be rocket surgeons
That does seem odd- even for GM- to run a ground from the passenger compartment to the engine bay. I seem to recall the grounds on that bolt to be (at least one of them) for the HVAC items on that side (?). Bear in mind, my car was a wiring nightmare when I bought it, so who knows if mine was correct.
Glowsock
Jul 24, 2025 03:15 PM
eightsixseven
Dec 16, 2024 01:50 PM
Jae992
Aug 27, 2015 09:07 AM
Glowsock
Aug 26, 2015 12:28 AM
Armored91Camaro
Aug 25, 2015 12:01 PM
