timing cover
Old May 11, 2011 | 09:30 PM
hartman's Avatar
Car: 1992 firebird
Engine: SBC 350
Transmission: TH350
timing cover
does anyone make a timing cover with the timing tab already attached at the 12 o'clock postion? or do i gotta buy the tab seperate?
Old May 11, 2011 | 09:44 PM
Re: timing cover
Not that I know of, other than GM. I could be wrong though. (well I am WRONG, with a capital R, but besides that, mistaken about this particular point, even)
Not that I know of... think about it... how you gonna bolt it on?
Old May 11, 2011 | 09:48 PM
hartman's Avatar
Car: 1992 firebird
Engine: SBC 350
Transmission: TH350
Re: timing cover
well they could weld the tab on or make one that extends way over. I think i found the tab here:http://www.summitracing.com/parts/MRG-4600/ but id rather but the cover with the tab welded in the middle if available.
Old May 11, 2011 | 10:11 PM
TNT_Z28's Avatar
Car: 1987 Camaro Z28
Engine: 355ci, XE262 , 650dp
Transmission: T-5, RAM clutch
Axle/Gears: 3.23 limited slip
Re: timing cover
im trying to think... (correct me if im wrong)
but wouldnt you have to notch the harmonic balancer in a different place if you move the timing tab over?
with #1 cylinder at TDC, wouldnt the notch on the balancer be pointing roughly at the 1:00 1:30 position?
i guess you could install timing tape on the balancer in an adjusted position
Old May 12, 2011 | 06:16 AM
Re: timing cover
Precisely: stock dampers for engines with that style of tab, which includes ALL of them that came in these cars, have their notch in the place for the ~12:00 tab. A typical aftermarket bolt-on tab is at about 1:30. This difference results in somewhere around a 35° error in th etiming mark indication.
That tab looks like it should work; it looks like it has the right length, which would have to be about 4". As long as it doesn't flop around too much it should be OK. I didn't realize somebody in the aftermarket had FINALLY, after more than 30 YEARS of this style of damper being used, NOTICED that the early-model thing they've been selling, DOESN'T WORK. Maybe somebody there FINALLY actually BUILT A MOTOR and in the process USED THEIR PRODUCT??
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
I'llrocya
Feb 2, 2016 11:43 PM
NBrehm
Aug 25, 2015 11:49 PM
