No Spark?
Old May 12, 2011 | 05:39 PM
Firebird Fly's Avatar
Car: 88 Formula Firebird, 86 Firebird
Engine: 305 TBI and crate 350
No Spark?
my 88 305 tbi turns over fine, has a fuel supply but no spark? suggestion? coil?
Old May 12, 2011 | 07:52 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: No Spark?
Could be a bad ignition module - it's inside the distributor - most auto parts stores can test it for free.
Old May 12, 2011 | 10:51 PM
tbutle03's Avatar
Re: No Spark?
do u have new wires if u dont pull the wire off the coil then take a screw driver and test the spark from there or is the coil built in to the distributor if not try that othere than that do the basic tune up maybe ur cap is worn down and that igntion module can be bad when u get the stuff have that tested if it works the go with a coil there only 19.99.
Old May 17, 2011 | 12:30 PM
Re: No Spark?
i replaced the entire distributer and after adjusting the timing it runs but every once in a while it will die right after i start it it seems to idle a little too low. did i not get the timing quite rite or what?
RedLeader289
May 28, 2019 01:47 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
HoosierinWA
Oct 7, 2015 10:15 AM
meeklay812
Oct 1, 2015 03:46 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
