major stump,odd thing happened
Old May 19, 2011 | 09:26 PM
formula 89's Avatar
Car: 89 formula,92 firebird
Engine: 91 355 tpi, 3.1
Transmission: 700 R4
Axle/Gears: 342 posi,
workin on a 3.1 in a 92 bird,new coil,new dizzy and the fixins,timing set at 0 tdc. tried to start and just cranks. plenty of spark. fp kicks in good and schraeder vavle seems too have good pressure(40 psi)....2 outa ten times it dropped to zero after pump cycle but i figured it should try to start. i hit the schraeder vavle to relieve pressure and twisted the dizzy to get wire outa the way and it made the pump kick in again. was like.....uh....and did it again with same result. why would it do that and why is it not startin????any answers or suggestions
Old May 19, 2011 | 09:33 PM
t-top havoc's Avatar
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
Re: major stump,odd thing happened
Plugs may be gas fouled, fireing order out of time, crossed wires somewhere.
IDK fuel pump issue.
Old May 19, 2011 | 09:37 PM
jimmy_pop15's Avatar
Car: 1986 Z28
Transmission: 700R
Axle/Gears: Stock
Your inline fuse for the fuel pump is loose. it's gonna be a fuse somewhere by the battery. find it and with the key on wiggle it and see if it makes the fuel pump kick on. If so you gotta fix it or replace happens all the time on these cars
Old May 19, 2011 | 09:54 PM
formula 89's Avatar
ran the wires like the manual said,123456,no crossed wires,prolly gonna try new pump tomorrow but it wont even start off ether so i dunno.
fuel pump fuse is tight an its behind the passenger headlight so movin the dizzy has nothin to do with the fuse if it were loose
Old May 20, 2011 | 06:40 PM
formula 89's Avatar
new pump installed today,still same issue. injectors maybe???? but like i said not startin off either either, did comp check and 150 on all cylinders. has a new cat on it so i dont think its clogged causing too much back pressure. im runnin out of ideas
and does anyone know an easy way to drain a fuel tank on these cars??
CORV3TT3
Aug 23, 2015 11:26 AM
stalkier
Aug 21, 2015 01:54 AM
Bob88GTA
Aug 18, 2015 03:31 PM
zeitghaist
Aug 18, 2015 07:33 AM
BurlyChev
Aug 16, 2015 09:08 PM
