Oil Cooler Hose
Old May 20, 2011 | 12:16 PM
sch151's Avatar
Oil Cooler Hose
Anybody have a source for the heater hoses that fit the KC4 'optional' oil cooler. The s shaped hose has a GM number of 14084012 but is discontinued from GM. I need two of them.
Thanks in advance...
Old May 20, 2011 | 12:28 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Oil Cooler Hose
I can't picture what it looks like in my mind right now, but you couldn't make your own out of bulk heater hose?
Old May 20, 2011 | 12:35 PM
sch151's Avatar
Re: Oil Cooler Hose
Hey thanks for the prompt response...the outlets on the aluminum hard line and the oil cooler itself are just too close to each other plus they are not closely aligned. Same applies to the block drain hole. Standard hose kinks when I try to use it. Someone had some pictures on this site that shows the setup. I think I searched "KC4 oil cooler" and found that.
Hotrodboba400
Dec 10, 2019 07:07 PM
tommy z-28
Oct 6, 2015 10:58 PM
Stryker412
Sep 20, 2015 06:59 PM
apie2546
Sep 5, 2015 07:40 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
