Head bolt thread sealant question
Old May 22, 2011 | 05:31 PM
spurgeon76's Avatar
Car: 1989 IROC-Z
Axle/Gears: 4th gen rear with 3.42
OK I installed my AFR 180 heads Saturday. I used new bolts with permatex thread sealant. For whatever reason, this morning I wasn't sure I torqued the bolts correctly so I broke the bolts loose and retorqued them. My question is should I have reapplied the thread sealant or do you think I will be ok?
Old May 22, 2011 | 08:07 PM
spurgeon76's Avatar
Car: 1989 IROC-Z
Re: Head bolt thread sealant question
Anyone?
Old May 22, 2011 | 09:03 PM
AutoRoc's Avatar
Engine: Vortec 4200 Inline 6 PT70 Turbo..
Transmission: 4L65E
Should be fine. I've done it with no issues and for good measure I run a sealant in The radiator. GM caddy pills or bars leaks.
Old May 22, 2011 | 10:34 PM
TNT_Z28's Avatar
Car: 1987 Camaro Z28
Engine: 355ci, XE262 , 650dp
Transmission: T-5, RAM clutch
Axle/Gears: 3.23 limited slip
I think it'll be fine. You'd be more likely to stretch those bolts and run into issues that way if you keep re-torqing them.
Frozer!!!
Jan 19, 2024 04:55 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
355tpipickup
Aug 25, 2015 12:54 AM
redmaroz
Aug 16, 2015 11:40 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
