HEI burning up ignition modules HELP!!!!!!!!!!
Old May 29, 2011 | 04:40 PM
Jake88maro's Avatar
Car: 88 camaro, 87 TA
Engine: 454 stock, built 468 400hp+150 shot
Transmission: WC t5, m29 t56 spec stg3 clutch
Axle/Gears: 9 bolt 2.77, 9 bolt 3.70
okay so the other day i started my camaro up, mind you a 454 carbed swapped car, just to keep it fresh. drove it to the gas station and it was missing something fierce hardly any power. so i replaced almost everything in the distributor, cap rotor and coil, besides the pick up and checked all the wires and still same miss. so finally after 6 modules im afraid to pay for another one just to burn up. im almost positive its a ground problem though because i notices out of no where my gas gauge started to work which it hasnt worked since i dropped the tank to paint underneath??? how could i fix this or what do you guys think is wrong??
Old May 29, 2011 | 06:54 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: HEI burning up ignition modules HELP!!!!!!!!!!
I have a bud with a 66 Chevelle, also burned up modules, until he bought a MSD brand module and hasn't had any further issues in months now.
Old May 29, 2011 | 09:00 PM
Irockz's Avatar
Car: 87 Berlinetta,work in progress
Engine: 468 BB,still in the build process
Transmission: TH350,3500 stall
Axle/Gears: 9" Ford,learning how to live under
pick up coil
Old May 30, 2011 | 11:41 AM
Jake88maro's Avatar
yeah thats the only thing i havent replaced how could that be doing it tho?
Old May 30, 2011 | 04:20 PM
Irockz's Avatar
If it's creating too much resistance,it will cause the module to overheat and cook itself.
Old May 30, 2011 | 11:50 PM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
I went through like 3 Accel modules in a many months... then bought a borg warner module and it's been fine since. Food for thought. I have an Accel coil also.
pjsparts
Oct 29, 2025 06:39 PM
BumpaD82
Feb 26, 2016 02:57 PM
Justins86bird
Sep 27, 2015 09:43 AM
RedLeader289
Sep 23, 2015 06:50 AM
BLK87Z
Sep 18, 2015 11:29 PM
