Oil pressure tap
Old Jun 1, 2011 | 10:43 PM
rscamaro305's Avatar
Oil pressure tap
I have an oil pressure switch on the drivers side of the block but there is a fitting on the back of the engine by the distributor that was broken and leaking oil. What is supposed to be there?? The engine is a 350 TPI from an '88 IROC. Thanks
Old Jun 2, 2011 | 08:20 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Oil pressure tap
Oil pressure gauge sender, if you don't have the combination sender/switch above the oil filter.
89GTAOz
May 16, 2020 09:31 AM
Prodigious
Oct 4, 2015 11:20 PM
solocus
Sep 2, 2015 12:14 PM
CamaroGuy350
Aug 30, 2015 02:56 PM
355sbcTPI
Aug 19, 2015 04:38 PM
