Is fuel pressure set hot or cold?
Old Jun 3, 2011 | 11:12 AM
EDGE's Avatar
Car: 1987 GTA
Engine: 5.7
Transmission: T5WC
Axle/Gears: 3:27
I'm trying to solve another issue but would like to start here. On a cold engine my Fuel press is 50psi at idle vacuum connected. When it warms up it drops to 40psi vacuum connected. Am I supposed to set the pressure at that point?
Old Jun 3, 2011 | 01:37 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Is fuel pressure set hot or cold?
Is it the same hot and cold with the vacuum reference disconnected?
Old Jun 3, 2011 | 02:47 PM
EDGE's Avatar
Car: 1987 GTA
Engine: 5.7
Transmission: T5WC
Axle/Gears: 3:27
No. Vacuum disconnected it goes up to 60psi
Old Jun 3, 2011 | 02:55 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
That's good, but is it the same hot and cold with the vacuum reference disconnected?
Old Jun 3, 2011 | 03:11 PM
EDGE's Avatar
Car: 1987 GTA
Engine: 5.7
Transmission: T5WC
Axle/Gears: 3:27
On a cold engine it's 50 with vac 60 without
Hot engine 42 with vac 50 without
92camaroJoe
Jul 29, 2023 07:57 PM
specialized
Jun 18, 2022 09:26 AM
R3500
Aug 17, 2015 12:16 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
