NEED TO KNOW SPECS
Old Jun 6, 2011 | 02:43 PM
82_Camaro's Avatar
Car: 82 Z28
Transmission: Turbo 200C
Axle/Gears: 3.43
NEED TO KNOW SPECS
i have an 82 Camaro 305 crossfire. i need to know what piston size to get. i am going to be going through the entire car and dont know what the bore size is
Old Jun 6, 2011 | 06:35 PM
TNT_Z28's Avatar
Car: 1987 Camaro Z28
Engine: 355ci, XE262 , 650dp
Transmission: T-5, RAM clutch
Axle/Gears: 3.23 limited slip
Re: NEED TO KNOW SPECS
What's prompting the rebuild?
Are you rebuilding the engine yourself?
Why rebuild your 305?
The proper procedure would be to have the block machined. That would determine your piston size. For example: if your cylinders needed .010 removed to make them round again, you would get .010 oversized pistons.
Old Jun 6, 2011 | 11:17 PM
82_Camaro's Avatar
Car: 82 Z28
Axle/Gears: 3.43
The car needs to be gone through so I'm going to beef it up a bit new pistons, cam, litters, rockers etc. I had already put headers and an exhaust on it but I'm going to pull the engine and go through it.
gord327
Oct 3, 2015 01:25 PM
mfp189
Sep 27, 2015 09:25 AM
wstephan96
Sep 25, 2015 04:28 PM
TX-SleeperC5
Sep 24, 2015 03:13 PM
angel2794
Sep 8, 2015 06:22 PM
