Quick fuel line questions
Old Jun 10, 2011 | 03:14 PM
blackbmagic's Avatar
Car: 1985 IROC-Z
Engine: 355
Axle/Gears: 3.42 10 Bolt Posi
Just rebuilt my 350.
.030 over
Flat top pistons
.480 lift 108lsa cam
ect...
My mechanical fuel pump was cracked from my original setup and I am in need of a new one. Looking at a 80gph pump.
My question is my original pump has 3 lines. The new pump has only 2. One inlet/outlet.
Can I eliminate my return? How can I work this out with an aftermarket pump?
Old Jun 10, 2011 | 04:59 PM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
Re: Quick fuel line questions
Did the car originally have a mech only fuel pump? Was there ever an intank electric pump? If so, was that pump ever removed?
Old Jun 10, 2011 | 05:08 PM
Car: 1985 IROC-Z
Engine: 355
I dont think so its an 85' iroc.
I bought the car without a motor, so Im not really sure what it had. The 350 I bought had a stock carter (I belive) fuel pump with 3 lines. I hooked the 3 lines up the way they were supposed to and it ran fine for many miles.
Took the motor out rebuilt it and now I am in need of a new pump. 80gph should be fine for my setup ~380hp
I was told I can just eliminate the return with a new style 2 port pump.
Old Jun 10, 2011 | 07:56 PM
travis401's Avatar
Car: 91 Camaro RS
Well if the car was stock FI, then it had an electric intank pump. If it was stock CCCarb, theres a chance it had an intank electric helper pump. If its got that intank pump, it would need to be removed for the dead head mech pump. If the tank just had a carb pickup then the dead head would be fine.
Frozer!!!
Jan 19, 2024 04:55 PM
theshackle
Mar 5, 2017 06:37 PM
Andrew6.688
Dec 13, 2015 10:59 AM
AkDrifted
Aug 17, 2015 07:45 PM
redmaroz
Aug 16, 2015 11:40 PM
