Neutral Safety Switch on a 92 Firebird 305
Old Jun 10, 2011 | 07:56 PM
sandiegobird's Avatar
Car: 92 Firebird Formula
Engine: 5.0 TBI
Its a 700R4 trans. Can anyone tell me where it is? Inside the trim on the inside or under on the trans? Are these simply to switch in and out? How can you tell if one is going bad (what symptoms should my bird have),
Old Jun 10, 2011 | 08:12 PM
t-top havoc's Avatar
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
Re: Neutral Safety Switch on a 92 Firebird 305
The lil plastic housing that has wires attached to it, which connected to the shifter itself--- under the center console.
Car will start in any gear selected if it's been wrongly re-adjusted or bad.
If you're in Park & it doesn't try to start, gently push the car til you hear a click or it stops rolling, which should Not be more than a few inches.
Make sure the selector is fully in Park
Haynes Manual has instructions how to re-adjust if that is the issue,
or maybe someone can tell you how. I can't find my manual!
( edit )
Make sure the cable is selecting all the gears on the trans-- 1 person move the shifter thru the gears, 1 person watch the selector on the trans.
Do Not do this with the car running!!
Last edited by t-top havoc; Jun 10, 2011 at 08:16 PM. Reason: cable & trans gear selector
Glowsock
Jul 24, 2025 03:15 PM
jhawkeye
May 25, 2022 06:33 PM
1992 Trans Am
Exterior Parts for Sale
Apr 4, 2016 12:50 PM
justin57
Aug 20, 2015 07:05 PM
MENINBLK
Aug 5, 2015 11:58 PM
