Bad mileage and fuel smell!!!!
Old Jun 13, 2011 | 11:57 AM
shone190's Avatar
Hi everybody,
I have a big problem with my Pontiac Firebird GTA 5.7 TPI since I bought it. So far I changed spark plugs, wires, distributor cap, O2 sensor, fuel and air filter, ECM, ignition coil, fuel pump, adjust timing to 6 degrees, but can't solved very bad mileage and fuel smell when engine is working
I got about 9 mpg in city and about 13 mpg on highway before and after change those parts.
Whenever engine is working, you can feel smell of gasoline, but I can't find where. There are no leaking, but smell of gasoline is around the car and there is smell of unburn fuel in exhaust.
There is no "check engine" light, and everything seem normal when drive the car, maybe some fuzzy work on idle, but nothing special.
Does anybody have any idea what to change next?
Old Jun 14, 2011 | 03:48 AM
shone190's Avatar
Re: Bad mileage and fuel smell!!!!
Anyone?
Old Jun 14, 2011 | 09:00 AM
xX89RSXx's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Is the smell coming from the engine bay? Maybe the charcoal canister has a crack or a line going to it is damaged. It is the black oval cylinder part on the drivers side behind the headlight.
Old Jun 14, 2011 | 09:15 AM
shone190's Avatar
I removed charcoal canister, but before that everythig were the same. I can smell gasoline from the engine way as from the exhaust too.
Is there a posibillity that Fuel pressure regulator or Fuel injectors are bad?
Old Jun 14, 2011 | 11:49 AM
southbay08's Avatar
You can check the diaphragm on the regulator as they have a tendency to dry out.
Then check your injectors...run the engine for a couple of minutes, turn it off then pull the plugs, if you have wet cylinders you have leaky injectors
bryan623
Mar 22, 2021 06:43 PM
NBrehm
Aug 25, 2015 11:49 PM
Bryan F
Aug 18, 2015 02:28 PM
Winchester1094
Aug 18, 2015 10:23 AM
