What to look out for when restoring a 6yr. old 'Bird?
Old Jun 17, 2011 | 08:46 AM
DaJulioShow's Avatar
Car: 1991 Pontiac Firebird
Engine: 5.0L V8 305 TBI
Transmission: Automatic
So me and a couple of friends want to restore my uncle's 1991 'Bird 5.0L V8 TBI. He gave tme he car since he moved away, but it's been sitting there for about 5-6yrs. What should I look out or during the restoration?
Before the car was just sitting there, it for sure had a bad fuel pump.
Iv'e looked under the hood a couple times, and the air filter holder is broken off. Anywhere I can get this?
Brakes are bad.
And other little minor things.
But from sitting there, what happens to it?
Thank you for your help, and hope this turns out a success!
Old Jun 17, 2011 | 09:04 AM
megan.artiaco's Avatar
Car: 1989 IROC-Z
Engine: 5.7L V8 350 TPI
Re: What to look out for when restoring a 6yr. old 'Bird?
When I bought mine it had sat for a few years. Some of the things we replaced straight away were the tires, drained and replaced all fluids, some of the hoses were dry rotted, all the filters.. fuel, oil, air. Some of the fuses were blown... well that's where I started. Hope that helps a little. I am no expert, but these guys are great and I'm sure someone will come along with some more info. Good luck!
Old Jun 17, 2011 | 09:14 AM
Thanks and has your car been workin well dispite sitting there for years?
Old Jun 17, 2011 | 09:19 AM
Car: 1989 IROC-Z
Well, I am still having an issue with it stalling and losing power. It is drivable though. It is an intermittent problem. When I started this project I came to terms with the fact that if I haven't replaced something, I can pretty much expect it to go bad. lol The guy who owned it before me had taken pretty much everything apart in the engine compartment and we had to put it all back together after we bought it. We still have no idea why he had it all taken apart.
Old Jun 17, 2011 | 09:25 AM
Oh I see, my car isn't very complicated fortunately. When my uncle was still cruisning in it, it rode strong and great with no problems. But now that he moved away time pretty much ate the car up. Has minor problems as I see it. Well, hopefully you resolve your problem and hopefully mine comes back to life.
Old Jun 17, 2011 | 08:46 PM
torque_is_good's Avatar
it's had fuel sitting in it for 6 years. It's had coolant sitting in it for 6 years.
It's had a tranny sitting for 6 years
it's had brake fluid and ps fluid sititng for 6 years
what would I plan for vs hope?
dropping and cleaning tank- you said it had a bad fuel pump as well
replacing some fuel and brake lines
replacing heater core
replacing radiator
replacing belt and hoses
rebuilding the tranny or maybe just maybe you might get away with a flush and then trying some white shepherd in it
adding white shepherd into the engine to soften the seals
replacing cap/rotor/plugs/wires
basically, have on hand at least $1,000 and tools. THe way to look at it is you'd have a $1,000 car that needs a little more work.
Old Jun 17, 2011 | 09:30 PM
jharrison5's Avatar
Car: '87 IROC
Transmission: WC T-5
Axle/Gears: 3.45 Posi
Basically you will need to change all the fluids (oil, trans, fuel, coolant, brake, and gear) New tires if they are weather checked, probably a new battery, and new filters all around. Check for rodent or other pest damage to wiring and soft parts. Lastly turn the motor over by hand before starting for the first time.
Old Jun 17, 2011 | 09:40 PM
TNT_Z28's Avatar
Car: 1987 Camaro Z28
Engine: 355ci, XE262 , 650dp
Transmission: T-5, RAM clutch
Axle/Gears: 3.23 limited slip
In addition to the advice in the posts above, I would go as far as to re-adjust the valve lash on the rocker arms. An engine that's been sitting for 6 years means that some valves have been sitting open that long, putting the spring pressure on the those valve's components.
Old Jun 18, 2011 | 01:30 PM
Ok I see, I got about half of that saved up so just need a lil' more. Thanks for the advice!
Im a newbie lol so how do you turn it on by hand?
Old Jun 18, 2011 | 05:15 PM
he did not say "turn it on"
he said "turn it by hand"
remove all spark plugs
pour a little oil into each cylinder.
put socket on crank pulley and turn slowly clockwise
having sat for 6 years the chances of it being "seized" are quite good but you must find out.
Old Jun 19, 2011 | 05:04 AM
Napster134's Avatar
Engine: 355 TBI
Transmission: 7004R
Axle/Gears: 3.27/42 ?
My dad had parked my firebird in 1994... It had not been touched until I picked it up in 2009... All I did was a new battery, oil, plugs, dist. cap, rotor, wires, fuel pump and a few vacuum lines and fuses... Once it was running, the things that went bad were the things I replaced, but to be safe, I would go ahead and do all of the recommended above.
Old Jun 20, 2011 | 07:24 AM
Yea ill change as many as things I can, but the weird thing is why did the "new" things you replace go bad?
Old Jun 20, 2011 | 07:25 AM
Ok sorry lol newbie here
skirocz28
Members Camaros
Nov 12, 2015 07:52 PM
David Frans
Oct 31, 2015 08:12 PM
mrbird
Oct 20, 2015 03:43 AM
Thornburg
Aftermarket Product Review
Oct 6, 2015 12:04 PM
