should there be fuel in this ? (pic)
Car: 84 T/A Recaro
Engine: L69 H.o
Hello
I have this canister purge valve in my engine and i was just wondering if there should be gas in it or just gas fumes . it has 4 tubes coming out of it and if i unplug the bottom one it has gas in it is that how it should be?
Re: should there be fuel in this ? (pic)
Your vapor canister could be saturated. Since you have a pre-1988 car there is a filter under the canister which should be changed or cleaned periodically. If the filter is clear and the vehicle is driven at cruise (highway speeds) for a length of time the raw fuel from the canister should be removed and burned - IF the vacuum lines are connected properly and IF the vacuum valves are working. There is a timed port on the carb and a TVS in the intake or water outlet to control the purge function, along with the purge valve.
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
