zz4 missing at wot
Old Jun 28, 2011 | 07:14 PM
q man's Avatar
Car: 87 ta
Engine: 350 zz4
Axle/Gears: 4-11
zz4 missing at wot
does anyone have suggestions why my zz4 misses at wot, only in low gear does it do it. its a 700 r4 tranny with od and a 3000 stahl
Old Jun 28, 2011 | 08:26 PM
Re: zz4 missing at wot
Plugs, wires, fuel delivery
Old Jun 29, 2011 | 03:37 PM
NEWMAN1786's Avatar
Car: 91 z28, 92 rs
Engine: 350 zz4, 305 tbi :(
is it carb or tpi or did you put your old tbi stuff on it
Old Jul 9, 2011 | 02:46 PM
q man's Avatar
Car: 87 ta
Engine: 350 zz4
Axle/Gears: 4-11
I got it, cylinder #8 spark plug wire was bad. I have another question, my dash is all electronic, after the motor swap my speed odometer is way off and the trip odometer doesn't work at all. I also changed the rear to a 4-11, I have no idea how to fix this one. Any help would be great
Old Jul 9, 2011 | 02:58 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
If the speedo works and the odo doesn't, the trouble is in the cluster as the speedo drives the odo. As far as correcting the speedo for new gearing, this is done by changing gears on the VSS drive. It works just like a mechanical speedo drive with a drive gear on the output shaft and a driven gear on the VSS drive. Different gears and combinations of gears are available to recalibrate the speedo. Look to a transmission supply for the gears and a list of combinations for different gear ratios/tire sizes.
Pac J
May 17, 2020 10:44 AM
Fireslash
Apr 11, 2016 06:43 PM
BrianI
Oct 3, 2015 12:57 PM
lewandom
Oct 1, 2015 08:15 AM
Damon
Sep 26, 2015 04:29 PM
