Please ID this part / help with noise
Old Jun 30, 2011 | 09:28 PM
MrPink's Avatar
Car: 1991 Pontiac Trans Am
Engine: 305 TPI 5.0L
Noob question: What is this thing circled in red?
I was cruising along and the engine lost all power all of a sudden and check engine light came one. I waited 5 minutes and it started fine and check engine light was no longer there. Now the part in the picture is making a high pitched pulsating noise. When I unplug the green connector, the noise stops. Also, now under the rear end (I think the fuel pump) is making a high-pitched squeal while the engine is running.
Any ideas?
Attached Thumbnails Please ID this part / help with noise-img_3986.jpg
Old Jun 30, 2011 | 09:36 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Please ID this part / help with noise
AIR diverter valve
Old Jul 1, 2011 | 04:01 PM
MrPink's Avatar
I was cruising along and the car died and lost all power. The check engine light came one, so I waited 5 minutes and it started fine and check engine light was no longer there. Now the AIR Diverter Valve is making a high pitched pulsating noise when the engine is on. When I unplug the green connector, the noise stops. Also, now under the rear end (I think the fuel pump) is making a high-pitched squeal while the engine is running...it is louder than it normally is.
Any ideas? Also, thanks Apeiron for the info.
theshackle
Sep 17, 2020 08:26 AM
LT1Formula
20
Nov 14, 2015 12:02 AM
armybyrd
Aug 17, 2015 08:59 AM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
1nastygta
Aug 8, 2015 07:38 PM
