Real quick question
Old Jul 4, 2011 | 08:27 PM
First_Formula's Avatar
Car: 1988 Formula Firebird (deceased)
Engine: l03 V8
Transmission: T-5 manual
Real quick question
Is it normal for when you set the timing on your car for the timing to go up as the rpms increase? i'm trying to set the timing on my 88 Throttle body 5.0 and when i rev it the timing goes up along with rpms then drops back down, Is this normal and could that cause a knock?
Old Jul 4, 2011 | 08:50 PM
Robby12's Avatar
Re: Real quick question
i don't know about the 88 but it should have a computer controlled distributor that you have to un-plug but yes it is normal for the timing to move around as the rpms are increased im more of a old school person ware you would just in hook the vacuum advanced hose,But your car is computer controlled
Old Jul 4, 2011 | 09:58 PM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
It's normal for a distributor to advance the timing as rpms increase. You need to set your timing as shown on this site and in the service manuals.
Old Jul 4, 2011 | 10:08 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Yes, normal. You need to unplug the EST wire, then start the car and set base timing, then turn car off, replug the EST wire, and disconnect battery for 5 minutes to allow ECM to lose 'memory' and make use of the new timing info and 'relearn'.
Old Jul 4, 2011 | 10:15 PM
Engine: l03 V8
alright thanks alot guys
redmaroz
Aug 16, 2015 11:40 PM
happyhapka
Aug 15, 2015 04:42 PM
jahblah
Aug 12, 2015 05:54 PM
