Rear End question please help asap
Old Jul 6, 2011 | 11:51 PM
SRichardson868's Avatar
Car: 1991 Camaro RS
Engine: 305 TBI
Transmission: Stock
Axle/Gears: Stock
1991 Camaro rs TBI has flowmaster muffeler with elderbrock high flow car and a cut-out. If i put 3:73 gear ratio in the rear end will i feel a difference? will it help me gain horsepower or make it jump off the line quick? will it be faster?
Old Jul 7, 2011 | 12:13 AM
Guest
Guest
Posts: n/a
Re: Rear End question please help asap
yes, no, yes, yes, in that order.
Old Jul 7, 2011 | 12:37 AM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
To be clear on that last yes. It will accelerate faster but not have quite as high a top speed for the same rpm.
Old Jul 7, 2011 | 01:26 AM
blue birdy 87's Avatar
Car: White 84 z28
Engine: Chevy 350
Axle/Gears: Posi and?
Im thinking about swapping gearing, how low can i go with having a top speed of 85+ with a th350 (3 speed auto) tranny? 4:11 too low??
Old Jul 7, 2011 | 07:16 AM
Depends on how much power your engine makes at whatever RPM that will force it to turn at, at that speed.
If it's a stock LG4 (the only 305 4-bbl in 87), it probably won't even go 85 set up like that. Or if it does it will take it about half an hour to get there.
Old Jul 7, 2011 | 09:07 AM
Guest
Guest
Posts: n/a
With a TH350 and 26" tires, a 3.73:1 gear will need at least 4300 rpm to go 85 MPH. That's insane. The typical LG4 only needs 2100 rpm to do 85 MPH. You might get 13 MPG, probably less.
Old Jul 7, 2011 | 10:45 PM
Ron U.S.M.C.'s Avatar
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
I changed from a 2.73,open rear to a 3.42 and Eaton posi. and noticed a considerable amount of change. Much nicer off the line . The best upgrade so far. If your going to do the gear change be sure to add a posi. while your in there. I suggest the Eaton.
hectre13
Dec 11, 2023 08:14 AM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
BlackBoulder
Aug 11, 2015 11:15 PM
