putting on vortec heads
Car: '91 firebird
Engine: 350 4bbl
Transmission: t56 6 speed manual
Axle/Gears: limited slip, 3.73 gears
i wasnt sure which section to put this in so general engine seemed good. i wannna put a set of vortec heads on the 305tbi in my 91 firebird and i found a listing on ebay with rebuilt vortec heads , http://cgi.ebay.com/ebaymotors/GM-30...#ht_500wt_1118 , but in the listing he asks to pick wich model and there is more than one 305/5.0l so which one do i choose? also the engine in there is not the original it is from a 91 buick roadmaster, does this make a difference? any help would be appreciated
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: putting on vortec heads
You are aware you also need a special Vortec only intake to bolt up to the new heads?
Those are 059, the 305 "Vortec" head; not, actual "Vortec" heads.
CHevy has discovered people like tha tword, and has been slapping it on basically EVERYTHING they make, just because .... people like the word.
In other words, when applied to ANYTHING besides 0062 or 906 castings, it's just a BUZZWORD.
AFAIK the only thing those heads have in common with actual "Vortec" heads, is that they have the same bolt pattern so that they can accomodate the CPFI system.
Meaning, you'll get basically old-school results, not "Vortec", but you'll have to pay for a "Vortec" intake.
I suggest re-thinking this plan.
Car: 82 Z28
Transmission: T400
"Vortec is a trademarked name for a line of piston engines for General Motors trucks. The name first appeared in 1988 on a 4.3 L V6 that used "vortex technology" to create a vortex inside the combustion chamber, creating a better air/fuel mix.
Now its used on a wide range of different GM truck engines."
Car: '91 firebird
Engine: 350 4bbl
i see, so this isnt a good choice then. i guess i'll have to keep looking for something else maybe if i can find regular aftermarket performance heads. thanks for the help
84z96L31vortec
Aug 20, 2017 12:16 AM
L98GTA87
Aug 11, 2015 06:55 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
