fuel injector question
Old Jul 19, 2011 | 08:39 PM
warren23's Avatar
I have a 5.7 tpi that I am going to relplace the injectors on. I can get injectors from autozoo at 45 dollars a piece. For that kind of cash are there any direct fit injectors that are better.
Old Jul 19, 2011 | 08:41 PM
warren23's Avatar
Re: fuel injector question
Almost forgot this 100 percent bone stock so I'm looking for 23 or 24 lbi would really like 22 though
Old Jul 19, 2011 | 09:39 PM
BlackenedBird's Avatar
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
Consider getting some Ford SVO injectors. Better spray pattern. Should cost you about HALF that cost for a full set of 8.
Old Jul 19, 2011 | 09:43 PM
warren23's Avatar
Are those a direct fit. I don't really want to have to make any mods and. Where would I get them. I hate to change subjects but I had an injector that ohmed at 9.2 the rest were 16.5 or above the oddball seems to be firing but why so low on resistance. Thanks for the help
Old Jul 19, 2011 | 09:50 PM
Car: GTA
They are a hair shorter, but still seal good & work. I personally have never done them, but they are highly recommended.
Old Jul 19, 2011 | 10:15 PM
southbay08's Avatar
We have the 22lb Bosch Design lll injectors that are a direct fit. Bosch is probably one of the most popular injector out there due to their reliablity, efficiency and performance. Ours are reman $165.99 for the set plus 10% off for tgo members. All injectors come with a 3 year warranty. If we can help you in any way, please give us a call.
Old Jul 19, 2011 | 10:46 PM
warren23's Avatar
southbay i will keep you in mind. I have another question. Are venom injectors a direct fit.
MustangBeater20
Oct 29, 2022 09:20 PM
bryan623
Mar 22, 2021 06:43 PM
redmaroz
Aug 16, 2015 11:40 PM
kyleb24
Aug 15, 2015 08:24 AM
Firechicken86
Aug 12, 2015 10:07 PM
