need help asap with auto shift linkage!
Old Jul 21, 2011 | 02:55 PM
Scootermunch's Avatar
Car: 1989 Trans am GTA
hey! my shifter wont lock into any gear. it's stuck in drive. the shifter just kind of flops through the gears, without locking in any, or changing gear out of drive. where are the connections to tell if something came undone?? please help, need this car going today!
Old Jul 21, 2011 | 03:09 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: need help asap with auto shift linkage!
Replace the shifter cable.
Old Jul 21, 2011 | 04:37 PM
found the problem... the bracket that holds the shift linkage (from tranny pan) has a disconnection between a rubber grommet and the plastic bit that goes into the metal bracket. does this grommet just slide into the plastic bit? i tried pushing it in and i just cant get it to stick.
any help?
Old Jul 21, 2011 | 04:53 PM
http://imageshack.us/photo/my-images...072100066.jpg/
picture...
see what i'm talking about?? does that pop right in? i cant get it in.
Old Jul 21, 2011 | 05:37 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
It's broken, you need a new one.
Old Jul 21, 2011 | 07:20 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Yep - that's a broken shifter cable.
Old Jul 21, 2011 | 07:47 PM
replaced it, it's all taken care of. the new one is kinda 'tight' and takes some more pressure to shift, but i guess that's better than it being stuck in OD. thanks fellers!
F-body driver
Mar 6, 2023 11:44 AM
AmpleUnicorn88
Interior Parts Wanted
16
Nov 29, 2015 05:45 PM
Magman
Sep 14, 2015 01:30 AM
NastyEngines
Group Purchases
Sep 8, 2015 10:14 AM
tonys91rs
Sep 2, 2015 07:07 PM
