Help getting the distributor not loose
Old Jul 25, 2011 | 10:02 AM
89 350's Avatar
Car: 1989 formula
Engine: 350 l98
Transmission: 700R-4
Axle/Gears: 327
I was wondering what the secrect is to get to the distribtor nut on the intake loose to adjust my timing the car is a 89 formula L98 TPI I have distributor wrenches but the only place ia can get the wrench to fit i have no room to loosen the nut i hit the fuel rail any tricks or suggestions thanks
Old Jul 25, 2011 | 02:27 PM
torque_is_good's Avatar
Re: Help getting the distributor not loose
If you have an offest distributor wrench you should have no problems
Old Jul 25, 2011 | 02:57 PM
89 350's Avatar
Car: 1989 formula
Engine: 350 l98
Axle/Gears: 327
i do it seems that when i get it on the bolt i have no place to turn it the wrench hits the fuel rail whats the best way to go after the bolt
Old Jul 25, 2011 | 07:38 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
http://www.sears.com/shc/s/p_10153_1...6&blockType=G6
Old Jul 25, 2011 | 09:19 PM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Remove the coil, it will give you more room. 2 bolts.
Old Jul 25, 2011 | 09:23 PM
Damon's Avatar
If it's never been loosened before it can be tough to break it loose. Liberal doses of penetrating oil (PB Blaster) overnight can make the job a lot easier. Most quality distributor wrenches can be wiggled in from several angles to get at it. And removing the coil will definitely get you extra room on that side.
Old Jul 26, 2011 | 12:47 AM
crytical point's Avatar
Car: 92 RS Camaro
Engine: 305 TBI
Axle/Gears: 3.08
I use a 3" and a 6" extension with the round tips so they swivel around the obstacles.
Fanatic1074
Oct 3, 2022 05:57 AM
RedLeader289
May 28, 2019 01:47 PM
HoosierinWA
Oct 7, 2015 10:15 AM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
Damon
Sep 26, 2015 04:29 PM
