coolant under valve cover
Old Jul 28, 2011 | 04:52 PM
Blue-Z28's Avatar
Car: 86 IROC-Z
Engine: 305 tpi
Hi,
coolant is bubbling- leaking from under valve cover, not a large leak,when engine is warm. Do I need a Head gasket? 305 TPI 127,000K
Thank you!
Old Jul 28, 2011 | 05:20 PM
Re: coolant under valve cover
Probably not... at least, not for that reason... the head gasket isn't anywhere near there.
Watch for where the leak actually is. Suspect sources include cracks (duh), head bolts (all 17 on each side go DIRECTLY INTO the water jacket of the block), rocker studs (they usually go into the water jacket as well).
Old Jul 28, 2011 | 05:25 PM
Stevolwevol's Avatar
Car: 86 IROC Z, 92 RS
Engine: 305 4bbl, 305 TBI
I don't think this is possible. If it is truly coming from under your valve cover, it would certainly be mixing with the oil. Are you sure it's not coming from the intake?
Hotrodboba400
Dec 10, 2019 07:07 PM
db057
Apr 28, 2019 07:45 AM
Nick McCardle
Sep 10, 2015 08:36 PM
tgp1990
Sep 4, 2015 06:24 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
