WHICH upper radiator hose do I need??
Old Aug 9, 2011 | 12:53 AM
leedavidalan's Avatar
Hi guys I have an 89 Iroc. It used to be TPI, but we put a new carburated motor in it and were having trouble finding an upper radiator hose that fits nicely. Have any of you done this type of conversion, and can recommend a hose? Maybe even the part number?
If it helps, one end of the hose connects to the radiator itself, the other end connects to a certain outlet thats on the motor. This outlet opens up towards the driver side.
Thanks fellas!!
Old Aug 9, 2011 | 12:57 AM
Shadow Z's Avatar
Car: Lots of 'em
Re: WHICH upper radiator hose do I need??
I went to advanced auto and got a stock upper hose for a 1986 305, and it fit on my carbureted 350 perfectly which I think I figured was from 1976 to 1979, from the casting numbers, had an Edelbrock performer manifold.
If it's a stock or close to stock manifold and stock radiator, the stock hose should go on just fine.
Pac J
May 17, 2020 10:44 AM
sheachopper
Jul 31, 2019 11:27 AM
