How much room is above the fuel tank?
Old Aug 16, 2011 | 03:45 PM
zacharyhorn's Avatar
Car: 91 Firebird
Engine: Turbo 355
Axle/Gears: 3.73:1 7.625" 10 Bolt
This past weekend I started to modify my fuel tank sending unit and run new braided line to the top of the tank (-8 an) I had the 90 degree bend a fuzz to far infront of the tank so I have to modify the set up again. I'm just curious as to how much space is on top of the tank when it's completely bolted in?
Old Aug 16, 2011 | 07:53 PM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Axle/Gears: 3.08 Posi
Re: How much room is above the fuel tank?
Theres only about 1/2 to an inch IIRC
Old Aug 18, 2011 | 10:42 AM
Car: 91 Firebird
Engine: Turbo 355
Enough to run a tube fitting and -8 an line to a 90 degree fitting on top of the tank in the stock routing?
Old Aug 18, 2011 | 09:30 PM
Pocket's Avatar
Car: 91 Trans Am
Id wedge some wood spacers between the tank and trunk to do that. Its REALLY tight with the stock steel lines, using a much bigger line with bulky (by comparison) fittings will almost certainly hit hard and you dont want to be bending bulkhead fittings esp when they're sealing your fuel cell
mustangman65_79
Apr 14, 2017 05:37 PM
theshackle
Mar 5, 2017 06:37 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
beachrodder
Aug 25, 2015 08:05 AM
AkDrifted
Aug 17, 2015 07:45 PM
