1992 Camaro wont Start HELPP
Subscribe
Aug 18, 2011 | 11:17 PM
the last thing i did was run over a puddle but idk if thats that problem or not but i parked it at home and the next day it wont turn over by the key! but it will turn over from starter any idea why it wont start????
  • Its not VATS already checked that
Reply 0
Aug 19, 2011 | 08:01 AM
Re: 1992 Camaro wont Start HELPP
I had that problem for years. Would sometimes take 10x of turning the key on and off and then it would finally start. Are you getting a single click sound when you turn the key to try and start it? I finally got sick of trying to trace the problem and just wired in a 12v push button switch from the auto store.
Reply 0
Aug 19, 2011 | 12:10 PM
Quote: I had that problem for years. Would sometimes take 10x of turning the key on and off and then it would finally start. Are you getting a single click sound when you turn the key to try and start it? I finally got sick of trying to trace the problem and just wired in a 12v push button switch from the auto store.
no when i turn it over by key im not getting nothing... and i no dome light will come on and headlights wont
Reply 0
Aug 19, 2011 | 12:51 PM
bad cable, fuse links, or connection
Reply 0
Aug 19, 2011 | 12:52 PM
remove and clean your batt cable at the battery. make sure you torque them when you re install.
Reply 0
Aug 19, 2011 | 01:04 PM
Quote: no when i turn it over by key im not getting nothing... and i no dome light will come on and headlights wont
Probably need to replace the battery cable that goes to the starter. More than likely the inside of the cable has been broken down due to corrosion.
Reply 0
Subscribe
