sensor help
Old Aug 19, 2011 | 10:36 PM
Gecz28's Avatar
Car: 88 iroc vert
sensor help
ok im trying to get my engine finished up. its a 350. i need help on which sensors/senders i need for the oil pressure and temp.
keep in mind i have a carb'd motor, a painless harness and im temporarily getting cheap autozone gauges. i do still have the hacked original harness sitting on garage floor if i need plugs.
any help would greatly be appreciated !!
Mike
Old Aug 20, 2011 | 01:22 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: sensor help
Do those gauges work with factory sender units or require their own ones?
Old Aug 20, 2011 | 01:46 AM
Gecz28's Avatar
Car: 88 iroc vert
Re: sensor help
not sure? havent looked at the cheap gauges too much yet. not sure if they are mech or elec?
Old Aug 20, 2011 | 07:38 AM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Re: sensor help
If mech then you don't need any senders.
If elec need to know if compatible with stock senders; if they are you just use the units from your old engine
HoosierinWA
Oct 7, 2015 10:15 AM
aaron7
Sep 30, 2015 09:15 AM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
dusterbd
Sep 29, 2015 08:40 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
