Sold please remove
Old Aug 29, 2011 | 12:38 PM
jaygt's Avatar
Car: 80,81,85, trans am
Engine: 4.9,301turbo,350
Transmission: all auto
Axle/Gears: 308,342,308
Sold please remove
Sold please remove
Old Aug 30, 2011 | 12:09 PM
Chevy86 IROC-Z's Avatar
Car: 1986 Camaro Z28 IROC-Z
Engine: 350 Tuned Port Injection, for now.
Axle/Gears: Posi - 3.23
Re: 1989 L98 firebird won't start. Please watch video :)
Where is the video?
Old Aug 31, 2011 | 10:17 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
Next time it happens, unplug the MAF and give it a whirl. If it starts, look at the maf circuit.
Old Sep 1, 2011 | 12:06 AM
jaygt's Avatar
Old Sep 1, 2011 | 05:16 AM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Re: 1989 L98 firebird won't start. VIDEO NOW UP:)
Could be the injectors going bad?
Old Sep 1, 2011 | 04:37 PM
ninetyone's Avatar
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
ohm the fuel injectors first then post back
ninetyone's Avatar
Axle/Gears: 3:42
http://www.youtube.com/watch?v=_g8PdrT0MCU
test injectors for ohms
Old Sep 1, 2011 | 05:43 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
oops
Old Sep 1, 2011 | 06:08 PM
jaygt's Avatar
Old Sep 2, 2011 | 09:26 PM
Mr Froman's Avatar
Car: 1990 Firebird Formula
Engine: LB9 - 5.0 TPI
Axle/Gears: 2.73, LSD
When cranking when it won't start, disconnect the wire coming from the ignition coil from the center of the distributor cap.
Hold it close to the block (use plastic pliers or something that won't let you get shocked) and check for spark while it cranks. If you have spark to the block, check for spark to the distributor the same way.
By doing this you are checking for spark from the coil, then checking for spark to the distributor.
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
RyanJB
Sep 2, 2015 01:27 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
Night rider327
Sep 2, 2015 04:18 AM
Night rider327
Sep 2, 2015 04:17 AM
