91 GTA Build Plan Suggestions!
Old Sep 2, 2011 | 02:55 AM
Dolly92ta's Avatar
Car: 1991 Trans Am GTA
Engine: 305 5.0L TPI
Transmission: Manual
Well this winter I plan on building my 305 5.0L TPI GTA. Some of you might think why not just put a new motor in there but my car only has 50k miles. So what im asking is what should I add or look into when i upgrade the car on suggestions or things im missing to make sure this process is a safe fly. Also let me know how you guys feel on the brand or what brands i should look into. Thanks
-Magnaflow 3'' Stainless steel dual rear exit catback-3.5''tips
-Pace Setter headers-1-5/8'' primary tubes, 3''collecter, mid-tube, painted finish
-Edlebrock Performer Intake Manifold, Polish finish, 4-bbl spread bore carb flange, Idle 5500rpm
-Sealed Power piston rings, oversize 0.030'', top ring 5/64'', second ring 5/64'', Oil ring 3/16''. Says 3.736'' Bore
-Jegs throttle body spacers
-Accell Performence Fuel Injectors 26lbs
-Edlebrock High performence In tank fuel pump.
-MSD Ignition 8.5mm Spark plug wires, Multi angle
-Accell Distributor
-Accell distributor cap & rotor
-Comp Cams its a Thumpr Hydraulic flat tappet cam nitrided Adv/Dur-295/313, RPM range 2500-6500, Intake/Exhaust lift: .500/.486
Also I was thinking of getting a lightweight flywheel but since all the power I'll be gaining is it safe to get a lighter flywheel because can it spin too fast?? I am getting all of this off of jegs.
How much of a gain do you think I would get off of all of this. Reason for the distributor and cap is because i want the best spark nothing cheap and I dont want anything to happen if im not getting a good spark.
Old Sep 2, 2011 | 01:08 PM
Dolly92ta's Avatar
Re: 91 GTA Build Plan Suggestions!
TTT help please!
Old Sep 3, 2011 | 12:29 PM
Dolly92ta's Avatar
Bump
italiano67
Dec 11, 2016 09:21 AM
gta90
Sep 15, 2015 04:00 PM
NinjaNife
Aug 23, 2015 11:49 AM
jharrison5
Aug 19, 2015 05:53 PM
sreZ28
Aug 14, 2015 07:48 PM
