So im pretty sure my car has a leaking fuel injector
Old Sep 4, 2011 | 11:31 AM
xsvtank's Avatar
Hey guys i have an 88 firebird formula with a 5.7l.
In the morning the car starts right up but after letting it sit off for a few min the car barely starts up. When it finally cranks enough times the car fights to startup and there is alot of smoke and a huge gas smell.
My question is if it is a bad injector how can i find out which one it is?
Old Sep 4, 2011 | 03:35 PM
DENN_SHAH's Avatar
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
Re: So im pretty sure my car has a leaking fuel injector
with a fuel pressure gage hooked up and the return line clamped off, pressure the fuel rail and then clamp off the pressure hose and watch the gage. it should hold unless there is a leak in the fuel rail.
if you have 1 bad injector, the others won't be far behind.
for the price for a set of remans from southbay or injectors plus, replace them all.
a leaking fuel pressure regulator is also a possibility. the regulator is normally easy to check, just pull the vacuum hose and look for signs of liquid fuel. be sure to cycle the key on to pressure the system up.
sometimes the regulator will only leak intermittently, so you may need to cycle the key on a few times and watch it for a couple of minutes between key cycles.
to check for lindividual leaking injectors, pull the fuel rail and pressure up the system and look at the injector tips.
if it still has the factory injectors and if your going that far, again i would recommend just replacing all of them and the regulator.
specialized
Jun 18, 2022 09:26 AM
RazorN8
Jan 7, 2022 11:44 AM
bryan623
Mar 22, 2021 06:43 PM
justin57
Aug 20, 2015 07:05 PM
kyleb24
Aug 15, 2015 08:24 AM
