HELP codes 12,33,45 92 Z28 with 383 acts like bad ignition
Old Sep 6, 2011 | 07:59 PM
1smoknz's Avatar
Car: 92 Z28
Engine: 383
Transmission: soon to be T56
Not sure where to start, I did pull the distributer acted like a stripped distrbuter gear. Tach was acting funny, doing a second gear burnout it read 7000 rpm and jumped all around.(700R4). If you shoved it in OD and luged the motor and kept it under 3000 rpm you could keep the car going almost normal. Seemed to run good at full throttel, but then if you let off the throttle I couldnt hardley keep it going. No backfiring but a lot of stuttering and missing. Also fuel pressure was great the whole time. Please help you can even call me. 608-289-1568. thanks Aaron
Is this post in the correct heading?
Old Sep 8, 2011 | 05:46 PM
1smoknz's Avatar
Car: 92 Z28
Engine: 383
Re: HELP codes 12,33,45 92 Z28 with 383 acts like bad ignition
I cant belive knowone as any idea on wht my problem might be.
89GTAOz
May 16, 2020 09:31 AM
db057
Aug 22, 2015 08:17 PM
Bryan F
Aug 18, 2015 02:28 PM
92camaroJoe
Aug 13, 2015 06:07 AM
