Dyno results are in
Old Oct 28, 2011 | 11:30 AM
  #51
84transamdude's Avatar
Car: 84 Trans Am
Engine: 383 Stroker
Transmission: Th350
Re: Dyno results are in
ok guys so I confirmed that my secoundaries are not coming open all the way.
Attached Thumbnails Dyno results are in-001.jpg   Dyno results are in-002.jpg   Dyno results are in-003.jpg
Old Oct 28, 2011 | 04:45 PM
  #52
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
If you have vacuum secondaries then they should be opening up as much as the engine needs them to. Im not sure how they're calibrated but if you have a serious problem elsewhere the combo that's hurting your power, your secondaries are going exhibit the same behavior (assuming they're calibrated correctly) as they are now. If the engine can only breathe so much air, then the secondaries are only going to open so much. And of course, breathing more air is the idea.
Old Oct 29, 2011 | 10:38 AM
  #53
Car: 84 Trans Am
Engine: 383 Stroker
Transmission: Th350
I have a bigger cam which creates less vaccum then a stock motor. I can change the spring in the diofram on the carb to get the secoundaries open all the way I was just wondering how much hp difference that could make.
Old Oct 29, 2011 | 11:24 AM
  #54
Damon's Avatar
Some, not huge amounts. I usually replace the stock plain color spring with the yellow one as a starting point.
Remember the vacuum secondary system runs on venturi vacuum which has little to do with manifold vacuum. It's a pure total-airflow-through-the-carb amount of vacuum. More airflow, more venturi vacuum, more secondary opening.
Falcon50
Aug 22, 2020 03:26 PM
LT1Formula
Oct 8, 2015 08:34 PM
Thornburg
Aftermarket Product Review
Oct 6, 2015 12:04 PM
gord327
Oct 3, 2015 01:25 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
