fuel pump
Old Sep 24, 2011 | 08:56 PM
t-roy383's Avatar
fuel pump
how do you energize a fuel pump on a 91 camaro. the manual says to put 12 volts on the g terminal of the aldl. does not work. is there another place to check it?
Old Sep 24, 2011 | 08:58 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
Re: fuel pump
you can do it right under the back of the car at the plug.
right behind the rear seats where the wires go thru the back firewall.
at the fuel pump relay
If its not working with power on the aldl your pump is prob. dead.
Old Sep 24, 2011 | 09:04 PM
t-roy383's Avatar
Re: fuel pump
thanks, the pump works, just cant energize it at the aldl, what wire at the relay?
Old Sep 24, 2011 | 09:16 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
Re: fuel pump
you sure your on the right terminal then?
Bottom Left.
Id have to double check replay wire color. I dont remember off the top of my head.
Old Sep 24, 2011 | 09:20 PM
t-roy383's Avatar
Re: fuel pump
nothing in that terminal. checked all the others also
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
