not sure where to post this but its a fuel question
Old Sep 26, 2011 | 08:46 PM
19f0rmula88's Avatar
Car: 70 Chevelle
Engine: 396
Transmission: TH350
Axle/Gears: 10 bolt 3.73
i was wondering what size the fitting was on the original fuel lines that come off the stock tank on an 88 firebird. i wanna run a braided steel fuel line but im not sure what size fittings ill need or if ill need an adapter fitting. the hose i wanna run is a -6 an so could anyone please help me out thanks
Old Sep 27, 2011 | 02:41 PM
1killerolds's Avatar
Re: not sure where to post this but its a fuel question
I'm quite sure that it is a metric thread, and it's either going to be 14mm or 16mm. I'm pretty sure it is 14mm x 1.5 thread pitch. I think I found the fittings you will be needing.
http://www.anplumbing.com/Adapters/Metric-25.html
I think you will need the 9894DBH Female Metric W/ internal Oring seat to AN male adapter. IIRC, the sending unit side of the line has the male end with the o-ring. this adapter should screw on to the line coming off the tank unit and has the AN -6 male nipple for the -6 line to connect to.
Old Sep 27, 2011 | 08:36 PM
Car: 70 Chevelle
Engine: 396
Transmission: TH350
ok great thank you. ill be going with a holley 750 double pumper. im not quite sure if ill need the other lines would you happen to know if i will?
Frozer!!!
Jan 19, 2024 04:55 PM
MustangBeater20
Oct 29, 2022 09:20 PM
specialized
Jun 18, 2022 09:26 AM
84z96L31vortec
Aug 20, 2017 12:16 AM
redmaroz
Aug 16, 2015 11:40 PM
