cr question
Old Sep 30, 2011 | 09:34 PM
uummm's Avatar
Car: 92 rs
Engine: 305 boat anchor
Transmission: t5
cr question
So I have a stock 350 out of a tow truck (or so I was told) but I'm curious as to what the compression ratio would be with 64cc heads (083 casting) and the stock rotating assembly, the piston appears to have a fairly shallow dish, 4 valve reliefs, and something like a chamfer before the rings, I was lookin at 10:1 pistons, but if I could pull off 9.5:1 id be happy, I'm only lookin to get 350-400 hp out of it. I will be doin a little bowl blending and maybe some gasket matching, lookin to run a cam with no more than. 510 lift and roller tip stamped steel rockers, also a 650 holley carb with a dual plane intake., I've done a little lookin on google and can't find what I'm lookin for, any info would be appreciated.
Old Oct 1, 2011 | 10:19 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: cr question
the piston appears to have a fairly shallow dish.
Without a accurate piston cc measurement would only be guessing.
Couple of cc difference in cylinder makes a lot of difference to static CR
Old Oct 2, 2011 | 05:48 PM
uummm's Avatar
Car: 92 rs
Transmission: t5
Re: cr question
A guesstimate would be fine, it don't have to be spot on, I'm just lookin to do a budget build and I could save money using what's there
MustangBeater20
Oct 29, 2022 09:20 PM
fasteddi
Sep 10, 2015 09:32 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
