quick question tps
Old Oct 3, 2011 | 05:40 PM
Firebird1990's Avatar
Car: 1987 Trans Am,1989 GTA
Engine: 5.0 Tuned Port Injection, 5.7 tpi
Transmission: 700r4, 700r4
Axle/Gears: 2:73 Posi, 3:27 Borg Warner 9 Bolt
quick question tps
what do i set multimeter to do set the throttle position sensor i know ohms but which 2000, 20k , ect?
Old Oct 4, 2011 | 01:21 AM
skibum2100's Avatar
Car: 1988 GTA
Engine: 5.7 TPI w/ Bosch III's
Axle/Gears: 3.27 Borg Warner 9 bolt
Re: quick question tps
I used volts and set my TPS to .54v, not too sure about ohms in this case. Set the voltmeter to the lowest voltage setting (probably 20) to ensure you can get below a volt.
Hope this helps.
Old Oct 4, 2011 | 03:15 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
And you need TPS plugged in and the key on so you have voltage going to the TPS;
otherwise there will be nothing to read.
You use Ohms to see if TPS is working ( unplugged ) ; not to set it
Old Oct 4, 2011 | 10:22 AM
thanks for thee info you guys, im still a noob with the multimeter and cars but its a learning process right.
Old Oct 4, 2011 | 11:02 AM
I H8 WWD's Avatar
Car: 89' IROC-Z
Engine: LO3
Axle/Gears: 10-Bolt/2.73
Nice tutorial. http://www.ladyada.net/learn/multimeter/
YouTube: https://www.youtube.com/watch?v=bF3OyQ3HwfU
BurlyChev
Aug 22, 2015 11:42 AM
redmaroz
Aug 16, 2015 11:40 PM
happyhapka
Aug 15, 2015 04:42 PM
jahblah
Aug 12, 2015 05:54 PM
