Keep blowing Fuel Pump fuse because of heated 02?
Old Oct 3, 2011 | 07:29 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Engine: 383 TPI Procharger D1SC
Transmission: TKO600
Axle/Gears: Strange S60 3.73
I keep blowing my fuel pump fuse and was wondering if it was because of my heated o2 sensor. I just switched to a heated o2 and wired it to the fuel pump wire that has power. Could this be enough to blow the fuse? If so, where should I wire it?
Old Oct 3, 2011 | 07:48 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Keep blowing Fuel Pump fuse because of heated 02?
I assume you wired it to the small wire on the relay that turns on the relay.
( Comes from Ign switch )
Should be on the large wire that is turned on by relay .( the one that runs to fuel pump)
Old Oct 3, 2011 | 07:53 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
I'll have to check tomorrow and post up which one I put it to.
Old Oct 3, 2011 | 08:05 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Ok I just checked and I wired it to the big orange wire (pin E furtherest left one). Is this correct?
Old Oct 3, 2011 | 09:43 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Is this correct?
If you have it on E terminal then it is wired direct to battery and O2 heater never turns off.
Will run your battery flat if you leave it long enough.
Should be on "switched " side of pump relay ; terminal A
so is only powered up when the pump running.
Which pump fuse is blowing ; the one in the fuse panel?
Old Oct 4, 2011 | 05:57 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Its the fuse in the fuse box that keeps blowing. (just noticed 20amp fuse for the turn signals is blowing as well). I switched it over to terminal A and it still blows the fuse. Is the 10amp fuse not enough or is something else causing this?
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
justin57
Aug 20, 2015 07:05 PM
92camaroJoe
Aug 13, 2015 06:07 AM
