Starting issue. Struggle turning over then start.
Old Oct 5, 2011 | 08:25 PM
svrider76's Avatar
Car: '83 TA DT500 HT
Engine: LG4
Axle/Gears: G80, 373
Issue: On cold start up the car acts as if it has a low battery. Initial turn of the key a few "rumph rumph" then the engine turns over fine and starts right up. Warm start ups seem fine. Hot start ups seem to have same issue if not worse. Stopped at gas station the other day and seemed as if battery was almost dead, then started right up.
Battery has ~12.7VDC , New alternator.
Suspects: Starter bad? Maybe drawing low amps? Voltage leaking somewhere in the ignition circuit? Could the battery earth ground be an issue?
Whats the best way to test a starter or rule it out? Any other key players here??
Thanks for the help.
Old Oct 5, 2011 | 09:25 PM
Chevynut46's Avatar
Car: 1986 z28 Camaro set for scca
Engine: 383 Carberated stroker motor
Transmission: LT1 T56
Axle/Gears: 9in with 3.50 posi
Re: Starting issue. Struggle turning over then start.
Check your timing. To much advance will cause difficult starts also.
Old Oct 5, 2011 | 09:34 PM
HeavyThundar's Avatar
Car: 81' Z28, 87' Iroc Z28, 05' GMC Z71
Engine: LB9 - 305 TPI - 190 H.P.
Axle/Gears: G92 - 3.23
As Chevynut said, check timing.
Load test your battery, a simple volt check with a voltmeter will leave you stranded.
Ohm out cables (ground cable included) for high resistance.
Sounds like a pickup i just worked on. Ended up being a weak starter.
Old Oct 5, 2011 | 09:41 PM
vistageek92's Avatar
Car: 1984 Camaro Z28 Clone
Engine: Bored .030, vortec sbc350
Transmission: Built T5 WC
Axle/Gears: 1999 Torsen 4:10 Locker
Mine does that. Its because the idiots put a 305 starter on it instead of a 350 when I had it replaced. It doesn't do it if you hit the ignition and let it some power surge through the circuit first.
Theyre gonna replace it for free with a 350 if/when it breaks.
Old Oct 5, 2011 | 09:50 PM
svrider76's Avatar
Engine: LG4
Timing is a good one, I should probably do this regardless as the car does have Accel Dist./Wires. Could have been installed wrong. The overall symptoms (the way it chugs for a second then starts up) seems to be starter but gotta peel back the onion.
What do you mean by "ohm out the cables"
specialized
Jun 18, 2022 09:26 AM
Orr89RocZ
Apr 25, 2016 08:28 AM
apo_bailon15
Mar 28, 2016 05:20 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
transamgta1Khp
Aug 17, 2015 12:18 PM
